rametric analysis
  • Thread starter Thread starter Mauri:66
Mauri:66
It often happens that at the end of modeling, in my case it is of particular automotive, some small radius on surfaces is forgotten. exist secrete you some system type rametric analysis that besides highlighting/coloring the rays according to their size highlighting or also indicate the live edges in the model?
may seem trivial, but with models that have about 2000 features becomes important :biggrin:
Thank you
the curvature analysis in this case highlights and colors all the radius values according to the value you impose but does not highlight the point where the radius is missing. In practice, I'd really need to highlight the edge.
I know that for this request the world of "model check" opens:eek:
maybe max meant zebra strips. where there are live edges you should see discontinuities. where there is continuous g0 (or g1?) you should see sudden changes of slope (but it's not exactly my sector).
with zebraous analysis we can see well the discontinuity between the union of 2 surfaces but the possible lack of a r1 becomes almost impossible.
I don't care if you can explain it to me. :finger:
you are!
you can try with search tool.
if you take the filter... then in the search result, you must remove all roundings.
I hope I will explain well! :wink:
diabolical as always, now I do evidence,
for correctness it is also right to put it in Italian, that is the search happens through the modified command >trova and then through the spigolo filter you get the desired search.
thanks to all
maurials
thanks to all
maurials
That's right! ;-)
the important fact is to exclude roundings from the research because otherwise the tangent edges proe sees them as edges and distorts your search. .
It'll be a bit about 2000 feature, but it's the only thing I can think of right now. :finger:
nx has a specific command (see image) already from version 00 beta :tongue:
excellent exactly what you need, clean and clear :finger:, ... do you want me to not implement what other programs already have for some time?:rolleyes:
or will it be possible to create a macro? :confused:
It's the same thing...
Yes you can make the macro of everything, even of that.
If you do it often, you better do it.
I'm trying but in fact the thing is a little more complicated and I'm afraid it doesn't give the same result because as you see in the annex, the edge in question is recognized as rounding, while in fact it is a living edge.
Hello Mauri
I'm sorry if I interfere... but I do as you were told to do to you.. by ozzy .. I usually save the search as a question.... surely you can save it also you and you do not need macro. .
example topology. Spigolo. selection of solid or surface selection or all model.. .
I hope I've been helpful
I compare you...
