rametric analysis
  • Thread starter Thread starter Mauri:66
Mauri:66
in case it was necessary:
1. open the native model or igs, step with solidworks
2. display it with edge shading
3. activate the display option - show - remove tangent edges.
4. hold the mouse wheel and rotate the model, in this way only the edges are highlighted.
maurials
maurials
Hi, Mauri. .
but this is a type of visualization that you can also use as escamotage to beam analysis ... effectively but not a real analysis that you want to look for the live edge on 2000 feature? ?
in my case is called shading with edges without smooth edges That you don't see tangent edges
Is that the same thing you mean mauri? ?
Hello rs4,
you are the same thing but it instantly highlights all the living edges that I have in the model, we call it also escamotage but it works and is instantaneous. as much as I can say meets my request.
Hello rs4,
and pro\e can't do the same from the ahhh maybe because it doesn't have black edges.... :biggrin: or did they insert them with creed?
