random automatic savers or not?
  • Thread starter Thread starter MatCad
MatCad
Good morning to you.
for years, but time is money now, I have always noticed that autocad performs automatic saves at some repeated pressures of the button (married by all of us) esc, sometimes when you return to the cad screen, sometimes even while you draw, but... outside the classic 10 minutes automatic rescue set. And when the design is heavy, it's an annoying break. can you avoid?
a second curiosity...with the same autocad, 2010, only a few years ago a new pc, the palette of fast properties (the square at 100pixel from the cursor), which I always used excellently, never required time and caused slowdowns, even to count selections of numerous elements. no I know that it happened (probably seven automatic updates) now just a hundred elements puts us 2-3 seconds to get property and display the bar.
It's a real computer countersensus if it first appeared instantly and now not all of a sudden, but the quick bar is useful, now I should not use it anymore......I tried with "system performance from the windows control panel between balanced, cpu at rest cpu at 100% but nothing changes; the hard disk is the same as last year and has enough space almost 40% hard disk, 4gb memory, very light drawings, yet it is now slow to appear and freeezera all the cad in those two three seconds.
Sure! go to autocad options, tab "open and save" and disable automatic rescue. . .
but in this way also disabled automatic rescue every 10 minutes of safety. . .
I would like him not to save himself in many other times at his discretion outside that time span.
If you tell him to save every 10 minutes he saves every 10 minutes.. I don't think it's going to save random.
