ratio/width error
  • Thread starter Thread starter andreaf93
andreaf93
Good evening to all,
I compare the warning that I attach when I apply the custom bending tolerance limit, using the thickness table and then defining the k according to the values of the gauge table, to a bending of the edge of a particular sheet.
What could be? the gauge table is always the same and in the past has never given me this warning.
What could be?
exactly what he says in the error: as for the inserted radius value has not been found a match in your gauge table, for the sheet thickness you are using (precisely says it exceeds it, so it says you have imposed a high beam to a low thickness, for which ratio value is not contained in your gauge table) then the fold is made using the factor k, precisely that set by default.
@smirro thank you for the answer in the meantime.
I gave you an example on a very simple detail having sp.1mm. A.webpin the photo see that it is selected as a bending radius 1mm and in the gauge table (you find it attached) that I currently use radius 1 is present.
I had this kind of problem, too. the problem is not solidworks but is the table file. the file intended as problems of "access, privacy win dows" ste robe here. I had these rumbles in the previous company that had a poor computer system.
try to make a new excel file and also try to do it in a different pc than where you work with solidworks.
try also with xlsx file format that you never know, although it is better old format.
I hope you do
Thank you. @mawell, I tried to save the gauge file for excel 97-2003 versions and it would seem to work. in case the error is resumed. Good weekend
