real time model update from table excel
  • Thread starter Thread starter Trial4life
Trial4life
I have a question about the interaction between solidworks and excel.
on solid edge, if I go in the "variable" section, and I make "path links" on the field of a variable (after copying a cell on excel), the size in question dynamically connects to that cell, and every change in the excel table involves a real-time update of the model, and vice versa.
is it possible to do such a thing on solidworks? I searched for many tutorials, which exploit the data tables, but I couldn't get a result so versatile and simple... and I couldn't even run the real-time update of the model. Besides, I just can't parameterize the model: For example, if I have an unformatted table according to the solidworks standard, I can't read the data properly.
if it is not possible to do so, is there any external plugin that allows it?
Thank you in advance.
up... .
coming from solid edge (an obsolete version) and being used to copy-paste variables, I have the same problem.
Does solidworks allow to do something like that?
If not how do I use an excel file (e.g. the one I used for myself) in solidworks?
ps. use sw2014 sp5.
in solidworks use the data table that is managed by an excel file that can be internal or external
