luca7691
Good morning to all,
I ask all of you, that you are definitely more experienced than me in using creo parametric version 2.0, a small help regarding a particular and delicate work that I am performing in my new job.
concerns the "ricalco" of various shapes of mechanical pieces of circular or partially circular form. to give an idea of the shape, consist of stars, half moons or rectangles/trapezi in which a circular sector is removed.
These templates have been detected in the field through a simple lime on a sheet, generally an a0 format, to which I applied a straight.
scanned (tif format), are imported into the model and located in the appropriate reference plan (images => add click on plan => search file and insertion) .
through the suitable command, always in the image menu, I carry the scan size in real scale (1:1) within the program.
then determine the origin of the image by view (view) => display model (model display) => image images (images) press the left mouse button, then click alt + maiusc while dragging the origin into the new location.
My problem! the rotation of the image, clockwise or anti-clockwise, which takes place through clicks. There is a way or a command to rotate the imported image (tif) precisely/micrometic. This facilitates me work in the recalculating of objects in which you have a straight side.
Thank you in advance all of you for your attention and for your vs answers/indications.
greetings and good holidays to all.
