record movement of a set
  • Thread starter Thread starter genesis1975
genesis1975
Good morning to all,
I would like to be able not only to drag but to be able to record a cycle of opening and closing of my asses... I can't... I attach the axieme that consists of a mechanism for sofa bed....the cycle goes from when the bed is stretched and horizontal to when it is closed to parcel. .
Nothing, the server says that the axieme is too heavy and so I can only post a photo...if you can tell me the sequence of operations you would do with motion analysis.. . .
If you have problems loading the overall axieme you can always split it into multiple zips.
Nothing, I tried to erase half the axieme but it still turns out too big... I will try Monday.. .
[edit]do so:
pack&go of the axieme in a unique folder
group all files in various zips of 5mb and attach them (if the site does not allow this size repeat grouping with 4mb zip)
good morning, I tried to subdivide it, but they are always underarms too big, that does not accept me.... if, instead, looking at the design, you could give me some straight, if you look at the part where there is the frame and where there is the yellow piastrone, form a quadrilateral that allows to close the whole... to turn the quadrilateral I will have to put a spinal motor in a certain fulcro
You don't understand,
I try to remarry them:
1 make the pack&go of the whole axieme putting as options to create a zip
1.1 from now on solidworks you don't need
2 take the zip and disappear it in a new folder.
3 now you have in this folder, hypothetically, 50 rows between assemblies and parts
4 selections, hypothetically 10 files indifferently whether they are axioms or parts and create a zip
4.1 the forum allows you to upload a 7mb file, so your zip file should be slightly lower than this.
5 delete files just zipped
6 repeats until compressed all files
7 attach zip files
how do you set the rotation angle?
Where? I can't use motion, so if you're referring to that module, I can't help you.
no, I tried to do the motion study on my own... at the bottom there's to give a sense of rotation to the main lever, while I set a limit angle coupling first, but the result is that it moves to snaps, it makes two and then it freezes there, I tried to increase the frames and speed', but something is not... tomorrow I will look at the tutorial, but it should already work so alone....
