record the commands made
  • Thread starter Thread starter michele81
michele81
excuse my ignorance but I have always used autocad at very simple levels. I would have the need to create a macro; does not exist in autocad the possibility as in almost all other programs to register the commands made with the mouse? is it necessary to enter the written code?
I apologize again but I'm just zero in this autocad sector.
in the last versions have inserted a "action recorder" (command _actrecord):
from the online guide:the share recorder is intuitive and allows you to create custom commands that can reduce the number of actions required to perform a repetitive task. during registration of a macro of actions, some important aspects must be considered....
thanks to all but now I understand why in the guide I found nothing...use the lt 09 that does not allow this command.. .
I'll find another solution! thank you very much anyway!
or you make a script... in practice a simple text file with the command sequence.. .
However, the option of the button with the macro (possibly integrated by some diesel command, the "mini-lisp" of lt) remains valid. .
