recovery component mancante
  • Thread starter Thread starter karma.pam
karma.pam
Hello to all, my assembled does not charge its components, I explain better, I create the assemblies with all its bound parts, except all but when I reopen the assembling in the model tree all the parts are marked in red because the classifications as "mancanti".even if I recover the parts and re-salve the assem, at the opening everything as before. I would like to point out that I have recently created and perhaps I have made a mistake, but I hope that my problem is not too "banal" to deserve an answer. Thank you all. .
means that the components are not in the work directory but you fished them from other folders, for this reason you do not find them.
you need to copy all missing components in the work directory or create search path in the config.pro to load components from other dir.
Meanwhile a thousand thanks for the answer...si,in fact I had created folders for each component thinking to better organize the work..instead.... can create a config.pro with its search path only for this together or is it still a general configuration file? and possibly how?
