rectangle beveled offset
  • Thread starter Thread starter goodwin
goodwin
I have a problem with autocad 2008.
with rectangle design tool a rectangle of 50x40 and fitting in the 4 sides with radius 2.
then I go to make a 2mm offset to the inside but the offset rectangle is not blurred by radius 2?! ! .
Is there any setting to set? Where am I wrong?
Thank you!
Thank you!
Where are you wrong?
in math!!!!
If at a radius 2, do an offset of 2 what radius you get?
I repeat the question perhaps easier:
if you make an offset of a circle 2 of 2 within which circle you get?
to you the answer!!!!
Great! !
I couldn't understand why setting a radius 2 of connection didn't seem to be blurred even the inner rectangle.
thanks for the answers... now it's all clearer on how the offset works!:finger:
