Are you referring perhaps to slenderness and therefore to the instability to the tip load?Bye to all,
Rectangular tank with flat bar ribs. I remember reading somewhere that there is a limit in the height/thickness ratio of the flat rib that you can use, but I can't find it. exists such an indication in some guideline and what is the value?
but in this case the dishes are not subject to peak load.Are you referring perhaps to slenderness and therefore to the instability to the tip load?
In fact, mine was a rhetorical question.but in this case the dishes are not subject to peak load.
