recupero file trail
  • Thread starter Thread starter bilbo94
bilbo94
Hello everyone, I am new to the forum and thanks to you I hope to learn many other things, including what I will ask you. I was working on creo then I appeared a mistake and I closed the program, obviously I did not save and now I am trying to recover it using the trail file, I opened the trail with the known block, deleted the part of the error and tried to reopen it with creo, but the program locks me, does not respond, how can I do?
try setting the set_trail_single_step parameter with yes value on the config.pro
you should have the opportunity to take the trail step step...... it seems to me to remember that maybe it is also cultivable of how many "passes" must go ahead to every confirmation...... I don't remember the variable now!
thank you so much but it doesn't even work like that, it blocks the same, I think it's just the computer that needs more power.
I don't know if the problem is the computer.... even to me every time I tried to recover the trail I stuck my computer
I hoped with creo2 the problem was solved instead it doesn't even work with this version
..... I doubt it is "colp" of the computer!!
can you post the trail file and the config.pro?
Are you an administrator user? Do you use windchill?
no I can't load them to post them, and no I don't use windchill, I don't know him, however I solved, I started the drawing that I was doing
I'm sorry! !
to upload an attachment go to the bottom of the page and find attached management, top right add files, select the file from the central window and conclude with fact.
