meccanicamg
the speech of the oil is a little particular because there are always some discrepancies.
basic know that for industrial mechanical gearboxes is used iso vg 220. depending on the temperature of the reducer or rotation systems, however, the same viscosity will be on average even if slightly different.
What do you mean you need some viscosity? How did you calculate it?
bearings must last millions of hours or what is believed by experience or by skf table.
normally a reducer is sized for 5000/10000 hours.
it is absolutely not advisable to use two different oils.
