toyo10
Hello everyone, I am a mechanical engineering student and Monday I have to deliver an exercise: topic reducer, in fact.
you are very available I have seen, also and upload images with really fantastic fixes! .
I would like to ask you two questions:
1) Is the reducer correct? if it is not where and how to correct it? (I put 2 images for greater clarity...it is always the same!)
2) I should quote and all the gear shaft with the piece pin.
on the quotas already I have made a culture on the forum and there are...but geometric tolerances just no! :
Apparently you can not put so ignoring the construction of the reducer (supports, bearings, etc.) as I was accustomed to doing for normal trees (see the picture I drew).
thanks to your availability!
For example, I think the bearings of the second tree were mounted or...
