reference component
  • Thread starter Thread starter and
and
save on a distinct components of two different together the same part can be on a "buyed" group while on the other "reference" to prevent it from appearing in separate ?
is the same .ipt file
This way
in a set will be in "default" and visible in distinct, while in other together in "reference" and will be excluded from the distinct
This way
but if the .ipt file of the object is the same if I change the from "default" to "refer" in all the assemblies where it is mounted becomes "referral"
No.
becomes permanent if you change in reference from separate components.
if you change it from the axieme browser with dx -> distinct structure components "reference" is such only in the context where the option is selected and not inherited in other axiemes.
at least you do not copy glue part/axis between assemblies
