Andrau
Good morning to all,
I would need to have a list of all the files to which a part refers or together.
I thought it was the command "find references" from the file menu (which I like because it also indicates the file/file not found paths if missing), but it is not exactly so.
For example, if a set inserts an empty part with only a superficial offset on another part of the axieme, the command "find references" reports me the connection to the axieme father (on which it is recalled) but does not say anything about the part to which the superfice offset is actually reported.
instead the command "external references..." from the feature tree of the axieme returns only the files to which a connection of feature is active (in the example the offset surface), but in the mode together it does not report the referenced files (recalled) in the same and above all does not indicate the file paths where it goes to look for them.
Is there a way to have the list of all links between the external files, which are recalled parts or feature links between the parts in it recalled?
and maybe even with the indication file not found or file path?
