regenerate the contours of a mesh
  • Thread starter Thread starter archilan
archilan
Hi, guys.
I shaped a ground starting with 3d polylines that I then stupidly erased
can you from the dederminated mesh regenerate the contours? a little like in the hatch I mean
Garzei for help!
to the
if you used supcoon with meshtype = 0 a polygonal mesh was generated, vice versa with meshtype = 1 you generated a mesh.
controls the type of object from property, in the first case maybe we can combine something automatically, in the second you have to use the method of the teenager. . .
It seems that the meshtype is equal to 1! cmq in the meantime I have recalculated and settled it! I have the same concern to know how to do it in case of meshtype=0, and above all, what is the difference?
Thank you very much
to the
