region of repetition
  • Thread starter Thread starter MaiMollare
MaiMollare
Hello everyone
I wanted to know if there is the possibility to arbitrarily order the components of a repeating region without using the lot regions
"to order arbitrarily" according to which principle ?
There are table repetitions, for example.
bye maxopus
I meant that I wanted to order the components without following an alphabetical order, or numerical but placing the sequence at my discretion, in my specific case according to the constructive sequence of the machine
creates a parameter (e.g. sequence) associates its values and sorts the table according to this parameter-
aminati
p.s. if the repetition region is not recurring, I think the default ordering is just that of the model tree.
Thank you very much
Unfortunately I have hundreds of pieces to insert and I was hoping for a different solution but it is actually the most practical solution to use.
with proes to end well you have to start well
Thanks again
I think with all the cads you should take a solution like that.
Since the axieme model tree can hardly, in a systematic and precise way, represent the assembly sequence ... other solutions do not see.
or you create the indexing criterion as you proceed, or do it in manina.
Careful! by means of repetition regions, if you enter a cell a parameter (&asm.mbr.sequence the one before) and the various axioms and parts do not already contain it, through the change value command selects the blank cells and automatically create the parameter and the checks the desired value. in two minutes create, assign the values and order the table as you want. more so to a cad we can not ask!
to the next
aminati
