sebas86
Hello everyone! I started using catia for aeromodellistic purposes. I read tutorials here and there so you have the basics to be able to move on. I ask you a question that will be of simple answer to you, but I, being a novice more than a beginner, can't solve. in an assembly if I make paste copy of a part happens that at the time when I change the original part from which I copied the others, they change all the glued parts. This can be undoubtedly convenient but for my purpose I would like it not to happen. in particular you can see in figure a series of centines, the first centine (the one with the arrow) and that I would like to change without changing the others. how can I delete this "link" that is generated when I make copy/paste?
Thank you so much!
sebastian
Thank you so much!
sebastian
