Tarkus
with previous versions was a trivial thing, with 2014 it is becoming difficult. .
Excuse the introduction.
So, I have a sketch with a block where some centers are present.
on some of these centers I make holes, (not on all).
if then I want to remove a hole from a center to do it on another, I go on processing change and from here, with the "centres" button highlighted, I click on the hole center to be deleted by holding down the mausc key, this I always did until 2013, with 2014 , it only works when it wants.
being a block I can't even clear the point from the sketch, even because I need it for other instances.
Is there another way or do I have to get rid of the work to give it back?
