RiccDS
hello to all, I'm trying to remove a part from one side, keeping the one to remove, or get a similar result.
I have two parts. the one to be removed (a cutting blade) that must remain unchanged. the second part is a plastic piece. In practice the blade goes into the plastic part and therefore in the latter I need a dig of the same geometry of the blade. of course I would like a link to the part of the original blade to be maintained so that if I make changes on that they are also reflected in the dig. I can copy the blade body into the plastic part to use the boolean removal function, but then I don't know how to accurately position the blade body compared to the plastic body.
any indication of how to proceed? Thank you.
