remove start axes and end radius on open view
  • Thread starter Thread starter ndonio
shading with edges without smooth edges
Mar
Thanks for the answer.
I think I wasn't complete in my show.
I need to remove the boards on the table view and not on the model.
on the properties of the view I unchecked all axes.
I think I have to change the style of quotation.
Do you know exactly what the variable is to change?? ?
for marcofa/thanks of interest.
I think it is limiting and expensive to have to use to clear the lines (we imagine if we had to handle a high number of designs).
I can add that the same subject has already been dealt with by dandao on 27/09/2012 and as it has been said in that section almost certainly it is necessary to set the right varial in the standard (obviously accessing in admin mode).
thanks to all those who will continue to be interested in how to overcome this difficulty.
Hello, unfortunately I have not been able even in administrator mode to find a solution, I hope someone can help us
Meanwhile you can put them in noshow easily
then if I don't remember badly you could fit the xml but I can't tell you if and what voice to change
more in the property of the view perhaps there is an option to hide the lines of the rays
Do tests and let us know
Here I am again
for falonev = to put the axes in noshow means how to manually delete them one by one and not only, then when you regenerate the view (if you made a change to the model) they turn on again.
in the properties of the view of the attached file at first discussion had been removed everything.
the solution is found in some variable in the xml.
What? ? ?
thanks to all
Hello to all boys
I'll take you back the experience I've made following some evidence.
I took the file of the part of the cat guide and found that doing the table of the open development of this model you can remove the lines of start and end fold.
It is therefore deduced that we must deepen the argument by placing attention to the model and not to the table.
I couldn't figure out what to set up yet, but I'm doing evidence.
greetings to all
I think it depends on the xml (standards) settings integrated in the catdrawing document.
question when do you exercise open an existing catdrawing or create a new one?
Hello falonev
I answer and bring back further experience.
then, I create a new one starting from a my start up with custom (xml) settings.
I say it's not standard.
to confirm what I say, I tried to create a new table where I set the standard iso catia and put the development plan of the model of the guide and a model (in sheet metal) from me made.
I confirm that even in this case on the model of the guide removing from the properties of the view the axes and the lines of center, this cleans all, while on my model no.
if you deduce that it should be some parameter on the model.
to continue I tried to get a valid start up from the cat's guide model for my job, but it doesn't work.
However I will continue with my evidence and if I find something I will let you know
I'm interested in the discussion. Could you pass the file you've indicated of the guide model I'd like to do some tests?
Good morning to all,
I return to the subject as I have the same problem as ndonio.
Can anyone help me?
claudio
