rename anonymous blocks
reggio
rename block from "a$c765d025c" to "mybloc"
hello to all, I often create blocks with ctrl+c command and then ctrl+shift+v
It is a system that I find very convenient and quick, but sometimes, as in this case, I find myself with a block that I would like to call it "mybloc" and instead the ctrl+maiuscolo+v has automatically assigned the name "a$c765d025c".
I now solve this way
- I add a position reference to a known block point
- I move the block
- Exploding
- I collect the block with _block + check name
- reposition the new block
- eliminate the position reference
Is there a faster and less blemish than mine?
_remains or renames both work on eng or it installations, so we have clarified properly for everyone, thank you.
Not really.
_rename works on any type of installation
rename (without the German) on installations in English
rename on installation in Italian
and now the explanation is complete, once and for all. thanks again to the clarification.
and if we want to enter the specific, the blocks to $..etc..etc.. They're not anonymous blocks. they have a specific name, otherwise they would not be renamed.
the anonymous blocks proper, in acad, are those that start with *u
further question: in case I have a design with 3 blocks "nomeblock1"
and want to rename only 1 of the in "nomeblocco2", would be possible with a specific command or will be obliged to
- Exploding a block "nomeblocco1"
- possibly change the block
- select and create "lock 2"
you would be obliged to...
more easily, two clicks on the block (enter in modality change block) and save it with a different name.
of course you will have to insert the new block created.
Thank you! true, I had not seen "save by name" even in modification block ... certain after it touches me anyway insert, delete the old, reposition where there was the old ... maybe I do first to explode+change+recreate already in place ... :confused:
anyway thanks for the tip!
hi, the important thing is the technique, solves so many problems.
drawings but mainly the blocks must have a geometric point, it will be the user to understand and decide which, coincident with the origin of the triad of the axes.
oi if you want you can insert sensitive points, dynamic block, which are evidenced in sequence to the pressure of ctrl in phase of insertion .
