jim78b
It seems impossible to me that in cad 2010 when I issued the block at the local then save me not to save the block with a different name! so I hold the original block. . .
If you issue it with the block editor you can save it with another name if you use modrif no!It seems impossible to me that in cad 2010 when I issued the block at the local then save me not to save the block with a different name! so I hold the original block. . .
saving it by name is one thing (in this case the procedure is the one indicated by tristan, creating a copy with other name), rename it another.uncomfortable, because with the mechanic I had allowed you to go with the cursor on the name of rename it to pleasure. . .
