rename copy together, under assemblies and parts and rename them.
graziano-g
Hello, how by title is it possible?
My need is to generate a copy at the level of assembly/subaxis/parts then rename/recode the whole composition but I tend all the components disconnected from the original, then with proper life from there, to maintain the machine of origin integrates and work on the new to change it without the changes affecting the original.
with d&d is possible, with the normal inventor tools is there a possibility?
I searched but I didn't find it or maybe I wasn't able to look good... .
I tried with design assistant but she quits.. .
Maybe I'm wrong. Also it tells me that some files are not updated to the version, they have to pass from 19 to 23, then there are unresolved ones, maybe that's why you plant...
I insist on the evidence, as soon as I get there
what you ask you do well with the vault, but in the absence you can try with app. copy assistant
hi, tried copy assistasnt, I do not like, too sleek, design assistatn too challenging or better too big the amount of objects to be renamed surely combined with my inexperience in using it.
the function assembles > series > copy while being all very simple to use performs the function I need.
with vault or d&d + top inventor qs is all another world, but at home I don't have it...
