rendering con proe arx
  • Thread starter Thread starter fabrizio_brescia
fabrizio_brescia
Hello, everyone. I searched in the forum but did not find a complete answer to this question.
I licensed wf3 and wf4 with additional arx paachetto for photorealistic rendering.
I wanted to ask you if someone knows if they are proe with this extension renders more or less similar to those made by hypershot, maxwell, etc., or by the most popular cad of the industry.
I would need this information to decide whether to invest on proes and deepen the use of this additional package or whether to take directly an external rendering program.
The first solution I'd like more 'cause then the characteristics (materials, lights etc.) would remain written in the together and then reusable.
If the reused were not decent, I should go to the second.
objects that I would like to see are in the field of lighting technology (so led spotlights, lenses etc.)
thanks for the advice
you with the arx you get excellent results without the problem of file conversion.
I suggest you study it.
if you have the chance to go wildfire 5.0, its rendering engine and mental ray.
Bye.
hi fabrizio, the wf4 rendering engine is nothing bad, although wf5 with mental ray is definitely higher, in my opinion. As for your specific case, the advantage of software like hypershot is the ease and speed with which you get excellent results, according to me the biggest limit of pro|e in this case is the bad management of the virtual room, makes the ax almost unusable in "prospect" mode. Moreover for lighting and similar hypershot is heavily limited by the lack of light sources, better then maxwell or fry render.. .
concluding, considering also the bagarre on the rendering engines luxion/bunkspeed and the prospective implementation of iray in pro|e, I would recommend you to point on the ax in anticipation of an upgrade to the wf5.0
Palo
Bye.
thanks to all, I rated the passage to the wf5 I know that the rendering is better, but only for the upgrade of wf4 is about 4000 euros + the upgrade of arx that at the moment did not quote me.
so for the works I'm doing (at the moment I use proe to model electronic cards with ecad) it's quite expensive to switch to the wf5
I'll study arx by working on the help and the examples I'll find on the internet.
You know, taking a course now would be wasted because I wouldn't even understand the terms properly, maybe later.
the important (I hope to find also some written text or videocourse) is to understand initially the basic concepts and know how to move between the customizations of the lights, rooms, scenarios, materials etc., so first I will have to understand how to set the various options.
to use the ax well helps to install the graphic bookcases. check to have them but above all to have them configured well. Bye.
