rendering con solidworks
  • Thread starter Thread starter GiacomoSolid
the final image you want to get that resolution must have?
example 1000x2000 ? (vertical rectangle)
set the rendering resolution where the vertical resolution is 2000 and the horizontal is for example 6000 or made a 16:9 proportion to find what might be
When you do crop the height resolution will be what you wanted, the one in width, instead, what you need. .
to make quensto do not need to know sw
hi, maybe he wants a high precision of "painting", ... remember that when I banged the muzzle, in rendering I mean, it was advisable to set a "videocamera" and use that and its parameters to then get the render done as you want, not if you have already tried. (I now have the basic version of sw, the one that does not render and can't try again)
try with solidworks visualize, for my opinion it is much more intuitive than photo view even if you have to hand out a minimum anyway.
Thank you! I try and tell you;
See you soon! :-)
