tecnico_plast
I should repair the copper pipes that have been folded, in particular it is a couple of ø12 mm tubes for the installation of the radiators, and a ø14 mm tube of the gas plant kitchen.
the pipes had been left protruding from the wall for about 15 cm, ready for assembly, but some "animal" thought well to bend them.
I have not yet verified whether the copper is actually clinched, but I think it is, and I would like to understand how to repair the damage, especially with regard to the gas tube that emerges from the wall just in correspondence of the stove.
someone told me that the best solution would cut the ruined part of the pipe and weld a new brush, others instead advised me to use the appropriate fittings for the copper pipes. In both cases, you will have to run the wall slightly, but I wonder if there will be space to weld everything around the tube without doing too much damage to the wall: eek:
in any case, what would be the best solution?
