repair model
  • Thread starter Thread starter MBT
MBT
Good morning to all
time ago we made a model in stereolitography from an aziendina area.
I don't know much about these technologies, but from what they told me they used a nylon loaded aluminum
yesterday a colleague with serious mental problems (and since yesterday also physical) damaged this model. nothing particularly serious, he detached a piece
I wonder what glue can be repaired. I imagine that cyanacrylates are not recommended in this case, since the surfaces are quite rough.
a vinyl glue? or rather an epoxy?
Any suggestions? experiences?
Has anyone ever broken a model in stereolitography? ? ? ?
Even if I did, I wouldn't tell you.... :-) Do you remember that block diagram like : funsia? > > > > > > > > > > > > > ■ > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
> no > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > t > o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o
apart from the vernacular jokes, of loaded aluminum I have no experience, but some nylon prototypes that I made realize, were made to pieces both for issues of size and to be able to sintering particular areas with orientations of the different layers (type hook teeth or other), the supplier assembled them with cyanacrylate.
I hope I've been helpful, bye.
Cyanoacrylate? I mean attack? and had a good grip?
sent by my asus_z00ld using tapatalk
cyanacrylate is normally used pel gluing of nylon and nylon prototypes loaded aluminum, attention technology is sintering and not stereolitography.
better add if possible nylon powder in the adhesion zone along with glue.
Good. Thank you!
