Gio_S
good evening to all, I wondered if there is a chance to repeat, right-click, not only the last command performed, but also the menu items I created with short sequences in autolisp.
I am born of the problem because I would like to act continuously, with repeat shots, selecting the cadauna units, simply recalling the menu item just executed.
Unfortunately, if I have just run the file code inserted in the custom menu item, and I click the right mouse button, my intellicad certainly goes to repropose the last command executed, but referring to the regular autocad command, last, which I had performed earlier. my command "custom" written in autolisp does not "remember" it anymore.
I don't know if I was clear...
Thank you!
g.
Thank you!
g.
