repeat wire processing
  • Thread starter Thread starter Zerorh75
Zerorh75
Good morning to all,
My name is tiziano work in mechanics and wire erosions for a decade. recently, a couple of weeks, I started working with visi 17 to create the cam programs I find myself quite well, except for a detail that I couldn't find in the guide and it concerns the repetition of the profiles once generated the program.
in practice created the first cut I would like to repeat the program 20 times at the distance of 20mm, or do I have to copy the profile and repeat on each the processing?
Bye-bye
ok I think I found, copy on set of points!
first profile copied 20 times,
second profile copied 20 times,
I created the group clinging with the copied profiles and put in order with the manual sorting option, to create the cut and its racking.
I think it works like that!
hi I use visi in milling and not as thread but I think you can operate in the same way.
if you open the menu "works " you will find the voice " transformations path tool" "shoot".
so by doing you can get path tools that always depend on the original path.This way if you have to make a change on the path by updating the main automatically you update everyone.
I thank you for your answer, I did a very quick test and it seems that how much you explained does not work with erosion processing, I did not understand well why anyway I know to do other tests and I let you know.
