repetition of "chain" in the axieme on controllable length perimeter
reggio
hi, I looked for myself and read the various old arguments but I did not find answers applicable to my case, in practice I created a sort of non-standard chain, which I will have to build and of which I made parts and together,
now the single "wife" axieme I want to put it in the machine's axieme and apply a repeat on curved path... I tried in various ways but what is simple and possible to do within a part seems that it is impossible to repeat in total: In short, I can't repeat my "daughter" set along the particular "path"... :
Can you help me?
Moreover it would be extremely convenient to be able to control the length of the development/length of the path to set multiple values to the step... How? even here it seems you can only in the command belt / chain but working in the parts... :
I don't know.
on the second you should set an equation on a portion of the path, but I have never been able to create a curved path made by a single "pezzo" so you should choose as a quota the whole and look for mathematical relationships between him and the length of the path.
cmq if in your intent there is a simulation I'm sorry to repeat the component and to tie it to the path because sw happens that you don't move a piece tied to a path for contact with others. you should get the most shirts together, tie it to the path to placerl and then delete the bond, and move it only through contacts.
I would advise you to use the chain belt function in the sketch and assign a defined length to the path. in order to make it you will have to leave "free" a wheel so that it fits the length.
in your set create a curve that follows the path and then use the repetition function along the curve.
Hello
I don't want to be wrong, but the repetition is not contemplated. along the curve (or I do not find it:biggrin:); only linear, circular or function driven (an existing repetition or set of holes from guided construction).
if you use the belt/chain from functions of together you create the path in another new part and with that then you can do the repetition guided by curve (but in the new part, which is however in the assieme and "right" tied to it)... I think.. I do that.
Marco:smile:
Hello
Marco:smile:
se inside the belt/chain part inserts the repetition of a simple feature (a hole, a cylinder) guided in turn by a sketch and to keep then hidden, can use in the axieme the repeat guided by the feature to repeat the jerseys.
This is a "talk" solution, eh... I pass the ball for that really shaped:tongue:
you are right both you and sampom, I have always done this repetition in one part and then repeated the components by hooking me to this repetition.
It's not the best.
Do you also need to move it later or just draw it? if it is not strictly necessary to shape the whole chain I advise you to do so.
... hello and thanks to all .. before writing I had already tried the directions indicated, but as I wrote I can only perform the repetition in one part but not in the assieme ...
Do you want to give me the right tip?
part = repetition in an example along a whole path in one part
the rest = composed chain + chain + path belt/chain
hi, for now I managed to create a part with a path (not belt/chain that I will try it later) and to make repeat the chain along the perimeter, the problem is that I do not understand from what point it begins to copy-roll the part when it arrives in the curve... The stitches in the curve are all out of place....
You know how to tell me the reason for rotation?
....I don't understand where it starts to copy-route the part when it comes to the curve... The stitches in the curve are all out of place....
:(...yes, it follows the path but follows it only with a point of the chain - we say that only a roller on 2 remains tangent to the created curve - the other instead is not tangent ... and in the chain turns must be tangent all 2... (see previous attachments)
help help... How do I do that?
hello to all
I'm my 26-year-old, and I'm a designer.
I have been using solid works for 5 years and currently using the 2011 version.
My company produces machines, especially conveyor belts and skin dryers.
I'll send this post because maybe I found a solution.
if you turn the sketch of the path in curve with the command "insert>curva>composita", you can use the curved repeat.
Hi I downloaded the shirt you created to try to give you a hand, but I don't understand what you want to do. . Could you do a sketch and tie it up?
