Ryo
I would need to replace the reference view of a section, without losing all the notes and quotas of the section.
on catia v4 there was a way to re-enter the "call-out" of the created sections that maybe had been deleted for some reason.
I explain better, I have a drawing with 6 sections made on a side view, then I have a passing section for the vehicle halfway which turns out to be equal to the side view. alsossa has 3 or 4 sections, and I wanted to save space, delete the side view and hold only the section, where to report all section lines of the deleted view, so as not to lose all welding notes and quotation.. .
Does anyone of you know if it is possible?
the version I use is v5 r17
Thank you very much
Thank you very much
