replacement cart
  • Thread starter Thread starter MaxBigno80
MaxBigno80
I need to replace an old cartilage with a new one already made (model drwdot) how can I do?
maximum
cartilages should be made using the sheet format (slddrt) and not the model (drwdot).
In the second case I do not think it is possible to replace the model with a new one. you must also see how you managed the cartiglio
exact, as stated by massivonweizen, you must save the new file you have done with .slddrt extension ("Save sheet size" and not "Save by name"), after which when you open the table with the old folder, right-click on "sheet1" in the tab on the left, click on properties, browse, and choose the new folder, then click on "Apply Changes". if you don't change it, repay the path until you click on "ownership" and click on "download".
