Damn t9...I wanted to write voult (no face) cursed fingers
I do not have 2022, it seems that the tool of 2021, as the drawings were made with 2019, fail the change in phase of implementation.do not need to reinstall version 2019, you can use inventor2022 utilities
hi, simply to change cartiglio is useless to shake ilogic, the procedure for transferring resources of the design works well and is simple and fast.Hello everyone
I put myself in the discussion with my request...
in the company we continue to update the cartilage, which is within the standard.idw ..
My request is if you can make a rule ion o una macro to update a table cartilage made a few years ago... without making a copy paste between tables?
inventor 2020...
Thank you for your patience
Hello, thank you for your interesthi, simply to change cartiglio is useless to shake ilogic, the procedure for transferring resources of the design works well and is simple and fast.
However, with ilogic it can be done because there is the function , but a more complex code must be set to copy the cartilage from a source file and paste it into the file in use , then if it has the same name, it overwrites and is already in place, if it has a different name then it must set it as active. I have the certainty that you can do it but for the moment I am not able to do it.
So I would do (and do) to swab the situation like this:Hello, thank you for your interest
I write more info to make the subject clearer:With the procedure for transferring resources of the drawing, can I change all the documents massively? I didn't even know the existence of that instrument...
- we in the company use the vault
- the cartella and the stardard.idw and always has the same name
- I was looking for a command to do it from time to time...
Wait, use the vault, then if you update the files out of the vault I think it breaks the boxes, wait for the vault to confirm or deny. I used vaults many years ago (vers. 2010) for these things was more flexible but now they told me they are more restrictive. once you replace a file in the workbook (of course the same name) , the vault gave an incompatibility error but with an extraction-archiveation cycle it reallined, now it seems that it is no longer possible. if so were they made a serious mistake in autodeskHello, thank you for your interest
Hello windreefSo I would do (and do) to swab the situation like this:
If I have to change a single drawing paper:
open source file in your standard.idw case
in the tree (at the left) open the resources of the drawing, select the cartilage and cup (ctrl + c)
open the target file
same procedure, open design resources and neckline (ctrl + v)
the procedure works automatically if the carts have the same name, otherwise it should be selected the new cartiglio , dx mouse and make it active
if I have to change carts to a whole folder massively , use wizard and even if the carts have the same name asks you if you want to overwrite , answer yes and you are finished, otherwise you have to open every drawing and make the new cartilage active
I don't know how to help you, but it would also interest me.Hello windreef
I used to copy glue from the new to the old, that's why I wanted to shake ion to do dirty work ... then I put the rule in the trigger after opening(as attached image)
I miss the rule though...
