Ing Italy
Hello.
I have a question to ask and I thank in advance who will answer me: as you will know when to introduce the dynamic equivalence is added to the moment of inertia of the biella (and also in other cases) a moment of fictitious inertia (can possibly also be negative and does not correspond to the real mass distribution in the biella) so that the scheme to two masses more fictitious moment jo uguagli dynamically the real biella.bene, as can be noticed in the link to page 67 when I go to write the
I wonder why you use only the fictitious moment and not the real moment of inertia since the moment of inertia of the equivalent system is the same as the royal biella and therefore =m(a) a^2 + m(b) b^2 +jo therefore in theory as obstacle to rotation there must also be the moment of inertia created by the two masses of substitution in a and b. so the question is: why use only the fictitious moment Thank you very much who will give me a hand, how you will understand from the time the exam is approaching.saluti
http://www.scribd.com/doc/38055075/48/metodo-delle-masse-di-sostituzione
