replacement plate
  • Thread starter Thread starter windreef
windreef
Good evening,
I have the need to change to a huge amount of parts the sheet rule as from now on the machines are produced as well as in galvanized sheet also in stainless steel. So I make the copy of the assemblies and parts and to avoid opening hundreds of files and manually changing the rule , I wanted to find a semi automatic method, a bit as from the separate of together changing the material to all parts , you have to select one to one (if the material is different) but from a list.
I don't know if I could explain myself
Perhaps it is possible to do so with an ilogic rule, i.e. change the material from galvanized sheet to stainless steel with the disposition of the axieme, then it would take a rule that when finding the material "stainless sheet" replaces the galvanized sheet rule with a stainless steel plate rule, previously created obviously according to the thickness that reads in the part.
But I don't know how to do it or whether it's possible.
I'm not sure, but I think the attached code can help you.
all files must be inserted in the assembly and you must operate ilogic rule from there
Code:
' start of ilogic code ===========================================================
' this code 2017 - luke davenport @ excitech
    sub main
        'check whether open document is an assembly and exit rule if not
        dim odoc as assemblydocument = nothing
        try
            odoc = thisapplication.activeeditdocument
        catch
            messagebox.show("this rule can only be run in an assembly file - exiting rule", "excitech ilogic")
            return
        end try
        'define assembly
        dim odef as assemblycomponentdefinition = thisapplication.activeeditdocument.componentdefinition
        dim ooccs as componentoccurrences = odef.occurrences
        dim oselecteddocs as objectcollection = thisapplication.transientobjects.createobjectcollection
        dim oselectedocc as object
        dim title as string = "change sheet metal rule for selected components"
        ' create arraylist to hold all the available sheet metal styles
        dim sheetstylesarray as new arraylist
        dim osheetdoc as partdocument = nothing
        dim osheetcompdef as sheetmetalcomponentdefinition = nothing
        do
            while true
                oselectedocc = thisapplication.commandmanager.pick(selectionfilterenum.kassemblyleafoccurrencefilter,
                    "select component(s) to apply new sheet metal rule to - (" & oselecteddocs.count & " selected) - hit esc when done")
                ' if nothing gets selected then we're done
                if isnothing(oselectedocc) then
                    exit do
                else
                    ' a part occurrence was selected - is it a sheet metal occurrence?
                    try
                        osheetdoc = oselectedocc.definition.document
                        osheetcompdef = osheetdoc.componentdefinition
                        ' if we're still here then the selected part is a sheet metal part
                        ' turn off all the occurrences of the selected part
                        call enablecomps(ooccs, osheetdoc, false)
                        ' add the document represented by the selected occurrence to the collection
                        oselecteddocs.add(osheetdoc)
                    catch
                        ' selected part is not sheet metal - loop
                        dim ques as msgboxresult = messagebox.show("please select a sheet metal component!", title,
                            messageboxbuttons.okcancel, messageboxicon.information)
                        if ques = msgboxresult.cancel then
                            ' user has cancelled
                            ' need to turn back on all the selected occurrences
                            for each od as partdocument in oselecteddocs
                                ' turn on all the occurrences of the selected part
                                call enablecomps(ooccs, od, true)
                            next
                            exit sub
                        else
                            ' loop
                        end if
                    end try
                end if
            end while
            if oselecteddocs.count = 0 then
                dim ques as msgboxresult = messagebox.show("please select components", title,
                    exit sub
                else
                    ' loop
                end if
            else
                exit do
            end if
        loop
            ' user hit escape with no components selected - exit
            exit sub
        end if
        dim errorlist as new list(of string)
        ' get the sheet metal rules from the first document selected
        osheetdoc = oselecteddocs.item(1)
        try
            ' get the sheet metal styles that are available in the document
            dim ostyle as sheetmetalstyle
            for each ostyle in osheetcompdef.sheetmetalstyles
                ' check that the style exists in the library - this means it'll be available to all the sheet metal documents that have been selected...
                if ostyle.stylelocation = stylelocationenum.kbothstylelocation orelse ostyle.stylelocation = stylelocationenum.klibrarystylelocation then
                    ' write sheet metal style name to arraylist
                    sheetstylesarray.add(ostyle.name)
                end if
            next
        catch
            ' do nothing
        end try
        ' error checking - no sheet metal rules in library
        if sheetstylesarray.count = 0 then
            msgbox("no sheet metal rules were found in the styles library. please populate the library before trying again", msgboxstyle.okonly, title)
            next
            exit sub
        end if
        ' sort the array alphabetically
        sheetstylesarray.sort()
        dim sheetruleselection as string = ""
        ' attempt to set the value of a parameter containing the list of sheet metal style names
        try
            multivalue.list("activerule") = sheetstylesarray
        catch
            ' parameter doesn't exist - create it
            dim oparam as parameter = odef.parameters.userparameters.addbyvalue("activerule", sheetstylesarray(0), unitstypeenum.ktextunits)
        end try
        ' ask user to pick what sheet metal rule they would like to apply (using the values in 'activerule' parameter)...
        do
            sheetruleselection = inputlistbox("specify sheet metal rule for selected part(s)", multivalue.list("activerule"), "none", title:=title, listname:="please choose")
            if sheetruleselection = "" then ' ask again!
                dim ques as msgboxresult = messagebox.show("please select a choice!", title, messageboxbuttons.okcancel, messageboxicon.information)
                    'need to turn back on all the selected occurrences
                    next
                    exit sub
                else
                    ' loop
                end if
            else
                exit do
            end if
        loop
        thisapplication.userinterfacemanager.userinteractiondisabled = true
        dim successcount as integer = 0
        ' apply the sheet metal rule to the selected parts
        for each osheetdoc in oselecteddocs
            'change active sheet metal rule
            try
                osheetdoc.componentdefinition.sheetmetalstyles.item(sheetruleselection).activate
                successcount += 1
            catch
                'error checking
                errorlist.add(osheetdoc.fullfilename)
            end try
            call enablecomps(ooccs, osheetdoc, true)
        next
        thisapplication.userinterfacemanager.userinteractiondisabled = false
        'inform user which parts have failed to update if there are any errors
        dim errorlistnew as string = string.join(vblf, errorlist)
        if not string.isnullorempty(errorlistnew) then
            messagebox.show("failed to update the following sheet metal parts without errors: " & vblf & vblf & errorlistnew & "." & vblf & vblf &
            "1) please check there is a sheet metal rule called '" & sheetruleselection & "' available in these parts" &
            " and spelled correctly!" & vblf & _
            "2) please check that the sheet metal rule can be applied manually without an error occurring", successcount & " succeeded", messageboxbuttons.ok, messageboxicon.exclamation, messageboxdefaultbutton.button1)
        else
            thisapplication.statusbartext = oselecteddocs.count & " documents - sheet metal rule successfully changed..."
        end if
        odoc.update()
        thisapplication.activeview.update()
    end sub
    ''' <summary>
    ''' this sub finds all the occurrences that refer to the supplied part document and either enables or unenables them
    ''' ' depending on the supplied 'enable' boolean
    ''' </summary>
    sub enablecomps(byref ooccs as componentoccurrences,
                    byval osheetdoc as partdocument,
                    byval enable as boolean)
        dim ooccenum as componentoccurrencesenumerator = nothing
        ' make occurrences that refer to this document 'enabled' again
        ooccenum = ooccs.allreferencedoccurrences(osheetdoc)
        for each oocc in ooccenum
            ' enable it
            oocc.enabled = enable
        next
    end sub
' end of ilogic code ===========================================================
Code:
    sub main
        try
        catch
            return
        end try
        'define assembly
        do
            while true
                    exit do
                else
                    try
                    catch
                            next
                            exit sub
                        else
                            ' loop
                        end if
                    end try
                end if
            end while
                    exit sub
                else
                    ' loop
                end if
            else
                exit do
            end if
        loop
            exit sub
        end if
        try
                end if
            next
        catch
            ' do nothing
        end try
            next
            exit sub
        end if
        try
        catch
        end try
        do
                    next
                    exit sub
                else
                    ' loop
                end if
            else
                exit do
            end if
        loop
            try
                successcount += 1
            catch
                'error checking
            end try
        next
        else
        end if
        odoc.update()
    end sub
    ''' <summary>
    ''' </summary>
            ' enable it
        next
    end sub
thank you so much, they gave me an ilogic rule in another discussion, it works perfectly with some tricks of use, cmq for the work I had to do it worked .
I also try this and I am happy with the results maybe it serves others
sub main
try
catch
return
end try
'define assembly
do
while true
exit do
else
try
catch
next
exit sub
else
' loop
end if
end try
end if
end while
exit sub
else
' loop
end if
else
exit do
end if
loop
exit sub
end if
try
end if
next
catch
' do nothing
end try
next
exit sub
end if
try
catch
end try
do
next
exit sub
else
' loop
end if
else
exit do
end if
loop
try
successcount += 1
catch
'error checking
end try
next
else
end if
odoc.update()
end sub
''' <summary>
''' </summary>
' enable it
next
end sub
I have inventor in English.
together:
ilogic - rules - add rule paste.
no I explained badly, how do you do here on the forum to post a text in the box as you did? for now I have inserted it free but usually in the forums do not want, then you understand worse I think
Code:
    sub main
        try
        catch
            return
        end try
        'define assembly
        do
            while true
                    exit do
                else
                    try
                    catch
                            next
                            exit sub
                        else
                            ' loop
                        end if
                    end try
                end if
            end while
                    exit sub
                else
                    ' loop
                end if
            else
                exit do
            end if
        loop
            exit sub
        end if
        try
                end if
            next
        catch
            ' do nothing
        end try
            next
            exit sub
        end if
        try
        catch
        end try
        do
                    next
                    exit sub
                else
                    ' loop
                end if
            else
                exit do
            end if
        loop
            try
                successcount += 1
            catch
                'error checking
            end try
        next
        else
        end if
        odoc.update()
    end sub
    ''' <summary>
    ''' </summary>
            ' enable it
        next
    end sub
ilogic rule to replace the sheet metal rule in the sheet metal parts present in a set.
It is necessary, for large assemblies, to prepare a list of pieces to change because the selection must be made either by the graphic area or by the tree and for large assemblies may not be so immediate if the files to be edited are many (as in my case) , but by printing a distinct part and highlighting the parts to be edited is very fast as process.
Code:
    sub main
        try
        catch
            return
        end try
        'define assembly
        do
            while true
                    exit do
                else
                    try
                    catch
                            next
                            exit sub
                        else
                            ' loop
                        end if
                    end try
                end if
            end while
                    exit sub
                else
                    ' loop
                end if
            else
                exit do
            end if
        loop
            exit sub
        end if
        try
                end if
            next
        catch
            ' do nothing
        end try
            next
            exit sub
        end if
        try
        catch
        end try
        do
                    next
                    exit sub
                else
                    ' loop
                end if
            else
                exit do
            end if
        loop
            try
                successcount += 1
            catch
                'error checking
            end try
        next
        else
        end if
        odoc.update()
    end sub
    ''' <summary>
    ''' </summary>
            ' enable it
        next
    end sub
It's the same one they posted to me, so it works . thanks
