Kaji
I would like to impose a relationship between two surfaces that was only valid for a certain range of a variable, unfortunately when I complete the classic expression "if ... then" and I pass "else" gives me error of syntax.
There is a way to get what I want, for example I want an object to move on a conveyor belt, then it is taken from an arm, so for example the distance between its center and that of the clamp that holds it is null (if x>10 then distance object caliper is = 0) otherwise there is no bond. thank you for the attention and excuse me if I explained badly.
