representations - location
  • Thread starter Thread starter chares82
chares82
Hello everyone
I use recently inventor 2018 and I have a problem on position representations, I hope some soul pia helps me :rolleyes:
I have to make 3 tables where on each of them I have to report different positions of a x horizontal axis, beginning, middle and end to understand us.
I set the design like this:
composed by:
- fixed part subaxis of the fixed machine
- subaxis of the linear axis with all the constraints set except the bond along the flexible axis of movement
- subaxieme of the mobile part linked to the moving body of the linear axis
I created a relationship between the fixed part and the mobile part of the linear axis where I set a maximum and minimal quota.
in main mode everything works perfectly, as change value to the bond the mobile part of the machine moves carrying behind all the components.
the animation of the bond also works perfectly.
the problem arises when I create the representation "position 1" , I go to replace (right on the relationship to be changed) the relationship and imposed the new quota with active the "position 1". the new quota remains highlighted in bold but the axieme does not update and remains in the initial position.
Am I wrong something in the procedure or should I activate some function unknown to me?
I did everything according to procedure... .
I just found out there's an active part that breaks the boxes, if we magically suppress it all works.
Fortunately it is not important for the boards and I solved but as I have time I will find out how to let it active.
