request for assembly
cacciatorino
I should make an import test of solidworks together with two different cads, could someone charge me a small set (two or three components) made with swx? The important thing is that at least one of the components hidden (not displayed on video) when the axieme is saved.
I suspect that, at least with one of them, the hidden files are not imported.
I'll try... But what do you do, you convert it to step/stl or iges?
How do you import it into another cad?
However, in the annex I hid the piston.. .
both solid edge and alibre declare to import directly axioms and solidworks parts.
I have seen from your set that solid edge works well, while alibre forgets the hidden parts (there are no propio in the model tree).
can I use your file to open a alert?
p.s. thanks for the help of course!
no problem was one of the first drawings fantasy fruit
