rescue management
deep70
Hello everyone,
I've been using catia v5 recently.. After a long break, I would like to ask everyone if you know how to explain why every time I do to save a set composed in turn by other sub assiemi the system always asks me to save through the rescue management.. place of images so that the type of message that gives me the system is clearer.
thanks to all for the answers and good work.. :-)
if you go to rescue management you should see in the status column which files require saving. probably opening the whole system realizes that below there is some files not explicitly saved or updated. in the status column you will see the files in edit. Try and let us know. maybe post the saving management window
thanks for the falonef answer, you are very kind and also I imagine very experienced.
I saw that the problem concerns a part that I practically duplicated, as it was enough to change only a set of holes, of course the part was saved with a different name both in the properties and as the filename. .
I wonder... could this affect somehow? or maybe there's something else about.. ?
I understand... what I would like to understand well, in order to avoid similar problems in the future is the exact procedure to duplicate a part file.. I'll explain. if I have a particular that differs from another only for one or two holes or its location or even better for the length of the particular itself to correctly duplicate it is enough to open the file replace the namebnation in the properties and quindo save it with the new name? or is there anything else to do?
the axieme that I have completed includes about three or four duplicated part files.. I hope they don't cause problems. was senseless to waste time rebuilding them from scratch again from the sketcher.. .
thank you for the answer and good work to all.. :-)
what you want to do is correct, of course if I want to make a new piece and I have a similar piece already made use of that x create the new...... Usually you take the drawing, with its part and maybe even its product you change the name from saving management and you have the copy to edit.
careful xò xhè if you have 4 equal pieces in a set , and you take this piece x change it , xché one is different you are changing them all !!!
the most appropriate procedure (x me) is to load the pieces you want to edit yourself, make the change and then replace the pieces in the assemblies............
the thing is much simpler to show but to explain you risk to make a round of words that are tangled .
As long as you don't understand the mechanism of connection reasoning of cat files do what I told you, because you risk seeing modified assemblies without you notice.
Thanks mcbramby.. I understood very well, you were very kind and competent. The same goes for falonef.
It is important to have help every once in a while from experienced people just like you.
hello and good work and day to all... :-)
... La procedura (x me) più appropriata è caricare da soli i pezzi che vuoi modificare said:
attention, before substituting the component, you have to save it with the new changes with a new name!
