lucadileta
hello to all and thank you in advance to all those who will answer me. I find myself solving a problem as described by the photo but I can not get physically sensible results.
a plate of small thickness but not negligible mass has an initial speed v0.
Such slab crosses a vertically aligned pair of rollers, of which, at the lower one, is applied a drive couple given by an electric motor while, the upper one, is free to rotate.
to the upper roller is also applied a force that will generate the friction necessary to press the plate between the two rollers during the passage of the same.
the peripheral speed of the lower roller I call it vf and represents the reference speed to which the plate must be accelerated at the end of its complete journey between the rollers.
the materials of the three cups is the same (steel)
the objective of the exercise is to assess the behaviour of the plate if:
- v initial plate is smaller, equal to or greater than the peripheral one of the lower roller (which constant vf wheel)
- evaluate the resistant torque generated by the inertia of the plate that is accelerated to vf
Could someone explain to me the setting of the problem?
