once built the adaptive component to what should I apply it? to a local mass or another family?definitely, with adaptive components. here is a species:
I created this family and now I should create through this family a suspended path/tunnel consisting of several blocks.you make a "panel" with the model called "low generic model in pattern" and then it is loaded into a family that uses the model of "adactive generic model" and is used "divided and repeated" with the first family on a divided surface. about more information about these topics in wikihelp or other similar places.
You could explain how to add constraints.I don't know how you did it. :
