retry smart component
  • Thread starter Thread starter mascla
mascla
Should I build an intelligent component that produces holes on two wooden panels one vertically one in horizontal someone can tell me the exact process of construction? ? ?
second play
second play
I press that until now I have never used this function. I tried to search in the guide and I will tell you that it is all well explained, so that without ever having made it I created one and I used it (for test).
synthetically you have to create a set with:
1- the component to make smart
2- the component with the functions that must be created after insertion
3- fixing elements to be used
do this press the smart component creation key and define which component, such as fixings and which functions and saves everything
to insert the smart component you have to place and mate your component as you would with a normal component, then click it with the dx and choose "intelligent functions".
However look in the guide, it is all well explained.
