reverse mouse wheel: how??
graziano-g
Hello, in the title my need....
I am facing this problem / need coming from inventor and solidworks.
I searched on the net, probably bad, but I couldn't find the solution, can someone help me or as I think I read in creo there's no such chance??
that is, would you want the object to shrug instead of magnify, but does it not work that by scrolling down the object also enlarges in solidworks?
Hello, try this
(oli::sd-execute-annotator-command :cmd "set_dyn_mouse_old_zoom_mode on")
as proof in the command line
if it doesn't work
(oli::sd-execute-annotator-command :cmd "set_dyn_mouse_old_zoom_mode off")
when you find the configuration that works for you, insert it in sd_custom
Thank you, I'm not clear, I'm going to take you.
you have to write in the command string, that is, the one where you insert the distances when you do the parallels,
in 3d environment
(set-dyn-mouse-old-zoom-mode nil) or (set-dyn-mouse-old-zoom-mode t)
in 2d environment
or
test the various combinations
in 3d environment
in 2d environment
or
Yes, you're right what I posted was for the 2d
hi, done all 4 tests, in 3d no effect, in 2d what reported in the image. . .
of course I copied the whole string of characters
from the appearance of the error it seems to me that you haven't copied the brackets, personally I can't do tests from home and also in the office I'm a little afraid to undress the settings.
said this I fear that with regard to the command of the 3d in reality reverses dynamic zoom, that is what makes you appear the arrow and then when you drag it down the frame moves away, not that of the simple rotellina (that generally I use very little).
looking also on foreign forums it seems to me that at least for the 3d the customization you request is not available, try anyway to ask for a possible softwarehouse that makes you support or if you can not just get used to try to ovviare with an evolved mouse that gives you more commands.
Hi, I put the string in full, as if nothing were....
with an evolved mouse the problem does not solve, if there is a software setting, if there is....
Unfortunately I don't have the program to try, have the courtesy to try so in 3d
(set_dyn_mouse_old_zoom_mode on) or vice versa (set_dyn_mouse_old_zoom_mode on)
