revit 2011 no longer works!!
  • Thread starter Thread starter omez75
omez75
for problems on the computer I had to change hard disk and then reinstall everything from the so to the programs I had already installed and working, now revit does not work anymore, I explain if I start a work from scratch without opening files already created previously and I try to create a wall or window for example the program closes immediately without signaling any anomaly but asks to send a signal to the autodesk that I promptly did, several times now but without results. Another case if I open a project already realized and therefore with many elements present also in the families loaded so as not to close the revit abruptly I must first copy a wall and then mofy it to work on it, but if I want to load a new one just press on the button of the walls here that the program closes.
the version I use is 2011 with the upgrade 2 installed, the operating system is windows 7 to 64 bit.
Can you help me? Thank you. .
Matteo
It is difficult to help you with these few info. have you contacted your dealer yet?
Yes by phone, but they answered me that I had to send him an email with the description of the problem, now I tried to explain it I hope in the best possible way, but nothing for now, the thing that I can not understand that before the break of the disk worked without problems.. .
