revit 2012 - crash causa materiali
  • Thread starter Thread starter Edoardo Bernardi
Edoardo Bernardi
hello to everyone, in an attempt to apply a certain type of texture, revit crashes and crashes. in particular if I change the texture to pillars and beams, or to facade panels continue in steel, the program crashes, for the rest everything normally works. what can be due to?
I crashed at the moment I tried
to change the texture of a material of
lacquered library.
I've had no trouble doing this.
- I add the material I care about
- I'm sorry.
- I save it in a new folder
- I change its texture
- I laugh again
- material application
proof you never know,
Maybe it works for you too...
@gfrank
I tried now to upgrade (for revit 64bit) but after replacing the dll file (renamed the previous) the program no longer works. I then restored the old state... I don't know why he does that...
@anchorage: if I duppose the material I care about, I crash when I renounce it. . .
Boh, advice? :
I don't know what else to recommend for the sw.
that is a hardware problem?
have you verified if the graphics card is compatible with revit? (on the adesk site are listed compatible tabs)
this evening I verify compatibility of the video card of the fixed computer. Thank you.
I take this post to know if by chance the problem has been solved, I find myself in this situation.
Matteo
what version and what "flavour" of revit are you using?
I realize I never wrote on the forum. I'll make a presentation.
version is 2012....flavour, emmm, what would it be?
But I make a statement that I noticed.
I revit 2012 installed and everything works wonder, video card nvidia 550, step to a picture fx500, decide to take a new tab and I buy a picture 600. I sell the fx500 and while I wait for the arrival of the new picture I use the integrated card of the mother board. with the integral begins a problem, I visualize the inverted colors, i.e. if I select a wall the temporary measures I displayed in blue, now they have become red/marroncino; I don't mind, so I say it's a problem due to the poor video card.
instead comes the new picture and the problem remains, I also find the crash in the material compartment.
Matteo
architecture, structure a mep?
architecture
I suspect you didn't install updated drivers on the card
mmm, in theory I do not believe; if I remember I downloaded the drivers from the autodesk site.
or that it is not actually using the picture
physically monitors are connected to the picture, so I think that is used, right?
other particular, for group reasons, I recently used revit 2010 which is not from any problem. 2012 I tried to restore it, delete it and reinstall it, but it always remains the same.
at the end the solution I found is to format the so and reinstall the software from there is installed properly.
Matteo
