revit 2013 - transprenza mori on windows
  • Thread starter Thread starter cadrev
cadrev
Hello guys, I have a small visualization problem with revit architecture 2103.
in view 3d the walls become transprentious in correspondence of the windows, or rather of the glass and not of the structure of the window. without stretching out in the explanation I attach an image that I think is quite explanatory.
Thank you very much
ok solved....just go on options (low when you click on r), graphics and disable the gpu ignition... ;)
:eek:
thank you so much! disabled, and in fact now it works.
but without acceleration means that revit will go slightly slower right?
I want to make a joke
but these autodesk programmers
first, they applied to enter
in jokes about the carabinieri
But they didn't want them?
mhm... it seems to me that it is the fault of the nvidia driver and not of revit. autodesk develops on hp workstations with pro video cards; they will not notice the foul.. .
you in fact should be a problem from the nvidia, but they cannot claim that every year you spend a boat of money to adapt the hardware you have their programs. ..however I hope in some update maybe nvidia drivers
I have the same hardware since the 2010 version and I have had no problem. Clear that if you buy the pc by spending 500€ at the mediaworld it is normal that you touch it every year
is not said, but some things will not work (such as ambient occlusion)
You mean in the new raytrace mode? or are you referring to anything else? (that at this point I think I do not know)
this is clear, but I have a couple of friends working with nvidia cards from 2000 euri (of course purchased years ago +-3) and with the new versions some problems have it... usually resolves after a couple of months with the release of the service pack. I mostly refer to autocad though. no problem with 3ds and revit (at least until today).
cmq thanks to all for the help
do not worry, in a few years,the use of such products will be exclusively in cloud :eek: there will be no more hardware problem, and other type:
- compatibility problems with other sw
- piracy:tongue:
- assistance :rolleyes:
... you will see that they will also do without dealers... :finger:
- piracy:tongue:
I also think it will come to this, but I don't think soon.. .
I think that however in Italy we will have many problems if what you say will happen... from the south to the north in fact you can not count on super connections!
