revit 2014 displaying linked file quotas
  • Thread starter Thread starter danipergo
danipergo
Good morning.
I made a model of a building that I connected on a file where I made the quotation of all the design, not to mix drawing and annotations.
This last file has been connected in a third in which I would only manage the layout and the legends (so a square file that recalls a quota file that in turn recalls the project file).
now, even by activating from the visibility/graphic options - revit links - the connected or even customized view, popping the odds, these do not appear in the screen, except for only two random odds in the drawing (among other things these odds are only part of a single continuous quota).
So, seeing these two quotas and not seeing any notice of loss of references, I believe that the procedure followed is correct, but in fact lacks about the other 490 quotas I designed.
Is there a solution?
I have specified the visibility of the quotas of the linked files, so much so that I can view 3. looks like a revit bug, more than anything.
unless I understand. I have selected as you see from the image.vistaCollegata_Revit.webpMore straight?
if you have the subscription contact technical support autodesk
I got it. I called them. have tried to carry out the procedure provided, concluding: "it's true, it doesn't work, but it should be weird!"
I think I'm gonna stake and hang in the same file, no comment.
Thank you
