vale79
Hello! !
Can you export the table of family types to excel?
Thank you very much
That's right.@ mario.biasi
Thank you very much
Yes, when you did the abaco you can from the file menu choose export then (discover below) abaco and create a txt file that you can then import into excel.Hello! !
Thank you very much
depends on which parameters you have to export.Okay, thank you so much!! !
So only the abbot, for the family table nothing to do, if I want to carry it all in an abacus, right?
Thank you: )
ok, ciao.? ? now I have to turn off x maintenance to the lines, tomorrow I tell you what I mean?? ?
Thank you and good evening!
regarding the server area to which you can link you can use two methods:Thank you very much @ mario.biasi !!!
ok, the link to the company certificate I can do it and it is also quite convenient; then I will have to divide approveds and certifications into several parts for products with multiple certifications but it is not a problem.
but at the moment I think there is no server area that can be linked; or can I link any file in the pc, just don't move it anymore?
so if I put "specified in the technical sheet" also in other items, like "maximum load, tube and material finishing, packaging and weight" 3 maybe even "description" would be good cmq? this always because when we update a tab this is updated in real time also on the site, so all the items that refer to it would always be updated.
yes the material I put it by hand because I could not manage it with the item "by category" as in the example you had left us:-( .
Thank you very much
That's right.
